by Kai98
If I change from PAYG to Flex do I get to keep my free boosts?
I'm currently on the EE £10 Pay as you go pack, and have like 10-11GB in free boosts (long story), so of if I changed to Flex, which just seem generally better in like, every way, would any of my boosts move with me or would it all get deleted?
Re: If I change from PAYG to Flex do I get to keep my free boosts?
@Kai98  The boosts are part of your current PAYG tariff so you’ll loose them if you move to a Flex tariff.  To my knowledge Flex plans don’t have boosts.
by Kai98
I think flex plans do have boosts, but only for data, which is what I'm after really, but I don't want to lose the 10+ I've already gained
