by Rrlc
How long can you pause a Flex plan?
I wanted to find out if there is a limit on how long you can pause a flex plan for as I will be out of the UK and EU for quite a while but know I will be back.
Also, can I switch from an EE 30 rolling sim plan to a EE flex plan without having to change my number?
Solution
Re: How long can you pause a Flex plan?
@Rrlc: You may pause a Flex Plan for as long as you like, but you need to remember to make some chargeable action at least once every 6 months to prevent your SIM going into hibernation, like any PAYG SIM.
To phone EE: The local rate landline number 0207 362 0200 or Freephone 0800 079 8586 - Option 1 for Mobiles; Option 2 for 4G WiFi; Option 3 for Home Broadband & EE TV.
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC = 2014: EE 20 Meg WBC
by Expert Contributor
Expert Contributor
@Rrlc I think thats gonna need a call to CS on 150 to answer those questions 🤔
Solution
Hi there @Rrlc
I can see you have had some great advice already.
If you would like to change your existing plan to a Flex plan give us a call.
If you have any further questions let us know.
