by timwis
How do I switch from pay-as-you-go to a Flex plan?
I just got a pay as you go SIM last week and wasn't told about the Flex plans. Now that I see them on the website, they look much better. I'd like to switch to one. Do I need to order a new SIM or can I switch? The store is a bit far so can I do this online?
Re: How do I switch from pay-as-you-go to a Flex plan?
You can't switch a PAYG SIM to Flex. You need to order a Flex SIM from Flex plans .
To phone EE: The local rate landline number 0207 362 0200 or Freephone 0800 079 8586 - Option 1 for Mobiles; Option 2 for 4G WiFi; Option 3 for Home Broadband & EE TV.
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC = 2014: EE 20 Meg WBC
@timwis  Before you go ordering a new sim and having to wait for it to arrive give customer service a call and they probably be able too switch you to a flex plan.
by Skilled Contributor
Skilled Contributor
As Chris says, it's perfectly possible to switch to a Flex plan. I have done so before.
by Ace Contributor
@timwis customer services can move you to a flex plan.
by timwis
Thanks all. Is there a way to contact customer services without being charged for contacting them?
Usually on PAYG you are charged 25p per call to CS but try calling them on +44 800 956 6000 (option 2, option 4) .
