by xanthi
New Member
Flex charges
I have just set up a new sim with a Flex plan, and I was immidietely charged for two months. Is it normal? I definitely did not sent any texts to start new plan.
Also, I do not see any ability to change or cancel the plan.
It only says: You cannot purchase a new pack until your stacked pack is active.
1 REPLY
Re: Flex charges
Sounds like you have bought an active plan for this month & a stacked plan for next. What exactly does text AL to 150 report?
MyEE / Menu / Flex
Then scroll down and tap the ‘Cancel Plan’ button.
To phone EE: The local rate landline number 0207 362 0200 or Freephone 0800 079 8586 - Option 1 for Mobiles; Option 2 for 4G WiFi; Option 3 for Home Broadband & EE TV.
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC = 2014: EE 20 Meg WBC
