by hollyh Investigator
error code 38
i am currenty in india. when im sending a text i keep getting error code 38. i can receive texts but cant send them. how do i fix this?
10 REPLIES 10
by Brilliant Contributor
Re: error code 38
May be that you don't have the international prefix on the number you are trying to send to.
For example a UK mobile number should be 447....... not 07.........
Re: error code 38
nope, tried that. ive input +91, just 91 and without 91. keep getting same error
Re: error code 38
OK I assume you have tried rebooting the phone so next step is to switch network selection to manual and choose another network. Doesn't matter if it fails or not. Then switch back to automatic and try sending a text.
Re: error code 38
tried that and still not working, ive checked my message centre number is correct. ive tried changing networks, ive tried rebooting with and without my sim card in... i dont understand how i can call this number and they can call me, they can send me text messages but i cant send them to that number.
EE Employee
Re: error code 38
Hi hollyh
Can you advise what type of handset you are using? Do you have access to any other devices to test your SIM in?
Regards,
David M
by Gazcun
New Member
Re: error code 38
Hi David_M,
I've recently just received my Nexus 6 and I'm getting the same error 38 message as hollyh along with an error 1 message. I'm in the UK and have been sending sms messages to the same numbers as always but 5 days into having the phone I cant send messages but they can send to me.
Your assistance would be greatly appreciated.
by Aloonatron
Re: error code 38
I also have this problem, in the UK
Error 38 when trying to send to numbers starting 850xx
Nexus 5x
Only happened since factory reset.
Other numbers (07xxxxxx) work fine.
Have tried power-cycling
EE Employee
Re: error code 38
Hi @Aloonatron
So I can get you the best help, please may I know if you are using a EE personal or business account.
Many thanks,
Lee
by SianT
New Member
Re: error code 38
I'm having the same problem suddenly today, I've tried restarting, taking the card out, changing network manually and no luck.. please could you help?
EE Employee
Re: error code 38
Hi @SianT
What app are you using for messaging?
I've done some searching in Google and it looks like it's a messaging app error.
Have you also checked your Message Center number is correct?
Thanks. :smileyhappy:
