by Almayer
images in gmail
Hi - what are the charges for image attachement in gmail?
Am I charged for attached image in the email if I am using wi fi?
Apologies for trivia but most of the info is about MMS - not email.
Many thanks
Almayer
Solution
Re: images in gmail
@Almayer   send as many images as you want by email you’ll not be charged especially if you’re using Wi-Fi, even if you your using cellular data to send an email with images it’ll only uses your data and you’re not charge for this also.
Solution
Re: images in gmail
by Almayer
Re: images in gmail
Many thanks Chris - very appreciated. That's great.
All the best
Almayer
