Highlighted
by Investigator
How do I set an avatar for my profile picture on ee community
I want an avatar picture for my profile on ee community is this possible
Highlighted
by Ace Contributor
Solution
Re: How do I set an avatar for my profile picture on ee community
Hi @Amelialouise99
If you click on your existing avatar then click my settings then avatars you will be able to change your avatar from there.
Thanks,
David.
Highlighted
by Ace Contributor
Solution
Hi @Amelialouise99
Thanks,
David.
Highlighted
by Investigator
Thank you @David 😊
Highlighted
by Ace Contributor
your welcome @Amelialouise99 🙂
