by Ace Contributor
Why can I not switch to HTML editor?
I am stuck on rich text editor I do not want rich text editor I want HTML. I have HTML editor checked and saved in my settings so why is it forcing me to use rich text?
by Ace Contributor
Solution
Re: Why can I not switch to HTML editor?
I did not try it - only because a workaround was not acceptable I wanted my account fixed and working properly.
However, it now seems to be working fine. I have just switched between rich text and HTML a couple of times and it is now recognising which one I have selected.
Both of my profile issues are now resolved!
Try taking it out of settings and select it manually each time.
Did that work for you @tm90 by the way?
by Ace Contributor
Solution
Recent solutions
