by Saraformum Investigator
Remove post
I'd like a post removed/ amended pleaee. How do I do that! Thanks
Re: Remove post
Good Morning @Saraformum
If you wish to edit or remove a post there is a cog at the bottom of your post. Select this and the options for editing and deleting will be there.
Thanks,
Katie 🙂
Re: Remove post
@Saraformum: But only within a limited time; 30 mins for Edit, a bit longer for Delete.
@Katie_B: How long for a Delete?
Re: Remove post
Hi @XRaySpeX
I have just checked this and it looks like I was wrong.
You are unable to delete the post, although as you have mentioned it can be edited if needed :).
Thanks,
Katie
by Profile closed
Not applicable
Re: Remove post
Hi, @Saraformum,
The great advice given by both @XRaySpeX and @Katie_B,
Should help you!
I've tried both suggestions!
Editing post via the little cog is achievable providing it's done within 30 minutes! 😊👍
Regards
mAh8v
Recent solutions
