by Prodigious Contributor
'@' Member tagging is causing spaces to be removed.
I've noticed recently that when typing a member's name preceded or followed by a [space], the space will sometimes be removed once the reply is posted.
In the editor when composing: Example @test Example
On the finished post: Example@testExample
In order to fix this, I have to edit my reply or post and manually re-add the spaces between the words.
I've searched the Khoros/Lithium communities and can't find anything on the issue so can only assume it is something that has changed recently...
There's an example of where this happened to me here. I attempted to tag @XRaySpeX and for some reason the space was removed between the colon and the beginning of the name.
Cheers,
Alex
If I solved your issue, please click the 'solved' button below to help others!
Re: '@' Member tagging is causing spaces to be removed.
@Alex_M Doesn't happen to me but I usually insert "colon space" after the tag @Alex_M :
@XRaySpeX I think I will have to start doing that too. It's just annoying that if I want to mention someone mid sentence it will sometimes join the member's name to the following word, as if I never entered a space 😭.
@Alex_M Yes, when I tag you @Alex_M mid-sentance i don't use "colon space' & it's still doesn't merge.
I guess my laptop has just had enough of me then! 😂
Hi @Alex_M
Hope you are having a good evening 🙂
Could you possibly try another device and see if the same happens?
Speak soon 🙂
