by HenryT
How do you attach images to posts so they appear?
Here is a test...
And above is supposed to be my attached image... But it doesn't appear when posted?
by Ace Contributor
Solution
Re: How do you attach images to posts so they appear?
Hi @HenryT  All images need to be approved so it will appear shortly once that's been done.
by Ace Contributor
Solution
Hello there @HenryT
Thanks for coming here 🙂
Is there anything we can help you with on the community?
Your image is now showing for you.
Speak soon 🙂
