by Brilliant Contributor
Error when posting
Every time I go to post a reply (and maybe a new topic I'll find out once I post this) it tells me my html coding is wrong when there isn't. I don't use the HTML tab I just type in the content box.
I have to go into the HTML coding to delete the rubbish for it to actually post.
Screenshot of the error message I am getting
UPDATE: Yes when I went to post this same error message about invalid HTML
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10/One UI 2.0)
Solution
Re: Error when posting
Yes it was my McAfee Webadvisor changing the html I have turned it off for this site.
15 REPLIES 15
@BrendonH : Has this just started happening?
What is the rubbish you are having to delete?
Started yesterday. I will try clearing my cache in case that helps but it gets rather annoying.
Everything highlighted and then everything after the </p> of the content I write.
Hi @BrendonH
I hope clearing the cache fixes this for you 🙂
Let me know how it goes.
Cleared cache, now testing....
by Pippincp Established Contributor
Just ignore it and hit post again. I used to get it a lot on the BT community forum, it resolved itself one day.
Clearing cache didn't work
Ignoring it don't work it just continues with the error
Thanks for trying @BrendonH
Have you tried another web browser at all?
Do you copy and paste from anywhere to post on the community?
Also, is this on a mobile?
No not copying and Paste on chrome will try edge in a minute.
No this is on my desktop
Testing...
OK...
working fine on Microsoft Edge, the issue is on Chrome.
Testing, think I may found the issue
Solution
Thanks @BrendonH
Great testing, glad you found out what was causing it 🙂
Thanks for letting me know.
Well found 🙂 !
