by Matt1959 Investigator
the system is busy, please try later
Every time I try to make a call I get 'the system is busy, please try later'.  I can receive calls and send and receive texts.  Pay as you go & am in credit.
Solution
Re: the system is busy, please try later
Thanks for checking @Matt1959
Please get in touch with Customer Care so we can take a quick look at your account. If they are unable to see any problems, they'll transfer you to our Tech Gurus so they can investigate.
8 REPLIES 8
@Matt1959  Is this just one number or any numbers?
Hi. I get the problem when I try to call any number.
Hi @Matt1959,
Thanks for visiting the EE Community.
Can you restart your phone and let me know if the message still appears?
If I power down the phone and then restart it I still get the problem.
Hi @Matt1959,
Are you a new EE customer?
Does the Network Status Checker show any problems in your area?
No I am not a new customer. It’s a pay as you go phone owned by my mother in law and she’s had it for some time. She doesn’t have internet access so I’m reporting it for her.
There are no network problems in the area.  My wife is on EE and her phone is fine.  Also the phone with the problem can receive calls and also send/receive texts.
Solution
