by Higgi74 Investigator
Voicemail
My calls are going straight to voicemail sent text to 150 its deactivated also do not disturb is off voicemail number is correct can anyone give me any more suggestions please
6 REPLIES 6
by Ace Contributor
Re: Voicemail
Is it possible for you to try the SIM card in another handset?
W
Re: Voicemail
Hi @Higgi74
Do you receive a signal?
What device do you have?
Re: Voicemail
Hi @Higgi74,
Welcome to the EE Community. Smiley Happy
I'm sorry to hear you are having problems receiving calls.
Is your phone showing a network signal?
Are you able to make outbound calls?
Re: Voicemail
Yeah have signal s9e
Re: Voicemail
Yeah can make calls out going
Re: Voicemail
Hi @Higgi74,
Thanks for confirming. We'll need to take a quick look at your account to get this fixed for you.
Please get in touch so our Customer Care Team can get this sorted for you.
