16-06-2019 07:47 PM
Hi.
I recently bought a new phone, a Nubia Red Magic 3 (Android 9.0, about the same hardware platform as a One Plus 7).
I plan to use it on EE, instead of my Samsung Galaxy S8 Plus, but so far I have a problem. When someone calls me I dont get the phone number or the name, just "Unknown caller".
What I tried so far:
1. I moved the SIM card into a different phone, it's working properly;
2. I tried a Vodafone and a Virgin SIM with the phone, no problems on those networks;
3. Phoned EE support, they did a Network Reset on my account, same problem. They also suggested a phone reset, which I did, without using a backup to restore. Same problem. The customer support lady ended up suggesting I should buy a phone from EE in order to avoid this kind of problem.
Wondering if anyone has an idea/suggestion on this matter.
06-05-2020 02:17 PM
so I found the answer on xda developers forum for anyone else who is struggling. You have to enter the country code before the number in order for the phone to recognise the contact when taking incoming calls!
16-06-2019 08:38 PM
@Nightwish If that EE sim works correctly when in a different device then the issue is the new device and it’s compatibly with the EE sim when a in coming call comes. This is not a network issue but a device/software issue not working correctly with the EE sim.
16-06-2019 09:51 PM
Thanks for your input.
I forgot to say I'm also in contact with the phone manufacturer who is providing (slow) support, hopefully will sort this out.
17-06-2019 08:11 AM
24-01-2020 09:49 PM
I had the same issue on my Red Magic 3
go to settings > Network and Internet > Mobile Network > Advanced (for the EE sim) and disable "Enhanced 4G LTE mode"
06-05-2020 01:55 PM
I'm having the same issue with the Red Magic 5g - and that menu doesnt seem to be there?
06-05-2020 02:17 PM
06-05-2020 02:20 PM
10-07-2020 09:08 AM
Hi guys, I got the same problem. I think it's on EE to fix this issue as it seems other network are ok even Lyca SIM works. I definitely will be looking to move once my contract is up with someone else.
10-07-2020 09:22 AM
Hi @Antony737800,
Are you having the same issue as the original poster? This issue has been marked as solved.
