by Do59 Investigator
Re: My phone won’t go to voicemail how Can I sort it out?
my phone won't go to voicemail it keeps ringing
by Ace Contributor
Solution
Hi @Do59
Welcome to the EE Community,
If you text VM ON to 150 it will set up voicemail for you.
Thanks,
David
6 REPLIES 6
by Ace Contributor
Solution
Hi @Do59
Thanks,
David
Thanks I will try that
hi david
Customer service not there at moment I will try tomorrow thanks again for
your help
Dorothy
by Ace Contributor
@Do59  what happened when you texted VM ON to 150 ?
they sent me a text message saying that I got no voicemail set up if I call
150 they will sort it out for me which I did they are close for the night I
will phone them tomorrow
Dorothy
by Ace Contributor
@Do59  ring freephone 0800 956 3146 from 8AM it will put you straight through to a tech advisor.
Recent solutions
