by Torymadden Investigator
Pinn to retrieve voicemail? Never needed before....
Am abroad can’t retrive my voicemail? Never needed a pin before.....
7 REPLIES 7
Re: Pinn to retrieve voicemail? Never needed before....
Hi @Torymadden
Welcome to the community. 🙂
Whereabouts in the world are you? Could you try manually connecting to another mobile operator?:
Device type Steps
Apple Settings > Carrier > Toggle Automatic OFF
Android Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Windows Settings > Mobile Network > Network Selection > Tap on start manual search
I believe that some operators require a PIN when others don't.
France, says carrier is EE!.....
Thanks @Torymadden.
Are you able to try connecting to another network while you're there?
Have you tried restating the phone?
Jon
Tried turning on and off. Made no difference.
Victoria
Sent from my iPhone
Thanks for trying @Torymadden.
What other networks were available when you tried to search?
It may be because you're connected to EE that it's asking for a pin. Is Orange available to try?
Jon
Yes it worked! Thank you. Does it matter which carrier I’m on?
It was just on Automatic and I swapped as you said to Orange then voicemail worked.
Thank you, hope this helps other EE users when they go away and can’t pick up their voicemail.
Victoria
Brilliant, thanks @Torymadden. 😄
It doesn't matter which network you connect to, as long as it works. 🙂
Enjoy the rest of your trip!
