by Alex93
How to setup voicemail
I'm going round in circles with customer services & texting VM ON to 150. I called customer services and followed the numbers to set up voicemail. After going through that it said it had been set up and to hang up. I then received a text saying to text 'VM ON' to turn on divert and 'VM OFF' to turn it off. When I then text 'VM ON' to 150 a receive a text saying that I have no voicemail set up and to contact customer services to sort it out and thus, the process repeats.
Any help is greatly appreciated
by Brilliant Contributor
Re: How to setup voicemail
Hello @Alex93 ,
Welcome to the community,
Have you tried texting VM off and then VM on, to see if that works? If you have no success, I would ring customer service to see if they can help and say that you have had no success, as it should have worked.
Good Afternoon @Alex93
I am sorry to hear you are unable to switch your voicemail off, I'd love to see if I can help.
I have sent you a private message for further information.
Speak soon,
Katie 🙂
by Mushy23
New Member
I have the same problem I am trying to set up Voicemail have rang 150 it sends a text saying to type VM ON this does not work it just sends a text saying voicemail is not setup have tried numerous times, Please help.
Hi @Mushy23.
Welcome to the community.
Could you try texting VOICEMAIL DIVERT ON to 150 and letting us know what response you get?
Jon
Recent solutions
