by stephen5000 Contributor
How to add a phone to EE signal booster box?
I have an EE signal booster box at home, working 100% with my phone. My girlfriend use to be able to connect to it with her old EE Rook automatically, but now she upgraded to an iPhone 5SE, and it won't connect. Tried turning both her phone & box off/on, but still won't connect via box. How do I get her phone to connect?
(Instructions say, "Up to four people can connect to your Signal Box at any one time.", so there must be a procedure to use further handsets).
Solution
Re: How to add a phone to EE signal booster box?
Issue now solved! Turns out her phone was 'WiFi call' enabled. This takes priority over the EE signal box. When 'WiFi call' is switched off, the phone automatically starts to use the EE signal box.
We only noticed it as during a call she was on I saw that the green light on the booster box was not flashing like it does on my old Nokia (Invented before WiFi phones!)
So, it turns out that iPhones are 100% compatible with the EE signal booster box!
15 REPLIES 15
Hello there @stephen5000
Thanks for coming here.
Have you tried re-setting the network settings on the iPhone?
Go to Settings > General > Reset Network Settings.
This will remove any saved WiFi passwords.
"This will remove any saved WiFi passwords."
mmm... she'd kill me if I did that, she has loads of saved passwords LOL Will wait and see if a solution is offered that won't upset any existing settings on her phone... Annoying that her old £30 Rook connected straight away, but her expensive iPhone is having a hissy fit!
Hi @stephen5000
This is just WiFi passwords that will be removed.
You could try giving us a call on 150 and see of our Tech Gurus can help you get connected 🙂
Shame you just can't register a phone number + IMEI number online and get it sorted... Hate calling 'help' lines as the last thing most do, is 'help'!
Hi @stephen5000
You can also access our online chat team at the bottom of this page, If you're with us on a pay monthly account.
They can have a look into this for you.
Leanne 🙂
I seem to remember it's something to do with an incompatibility between the iPhone using IPv6 but the Signal Box only using IPv4. If you could somehow change the APN Protocol to IPV4 Only in the phone's APN, that might fix it. I think some users have had to create a 2nd APN with that value as the default one can't be altered.
Any chance of that in English? LOL
The iPhone is incompatible with the EE Signal Box :smileywink:. GIYF.
Can you not make use of WiFi Calling instead?
GIYF! You are so funny... :smileylol:
However, other folk seem to have got it to work, I obviously just need to get one to post here, but thanks anyway...
Hi @stephen5000,
I would recommend using EE WiFi Calling as suggested by @XRaySpeX.
@James_B wrote:
Hi @stephen5000,
OK, what is "WiFi Calling" and how do I do that?
Hi @stephen5000,
WiFi Calling allows you to make calls using your home WiFi connection.
Please take a look at How do I use WiFi calling? for more information.
Hope this helps.
Solution
You mean that iPhones are 100% compatible with the EE signal booster box when they 100% avoid using it altogether :smileywink:!
I just assumed they were smart enough to know that the majority of WiFi is free, hence automatically prioritise that over an avaiable EE signal, which is often not! Come on, don't be so hard on yourself just because you were wrong! :smileylol: It's all good...
