by Hutch3 Investigator
How do I get Wi-Fi calling on my non branded LG G7 ThinQ
7 REPLIES 7
by Legend
Legend
Re: How do I get Wi-Fi calling on my non branded LG G7 ThinQ
Hi @Hutch3
You cannot if the option isn't available.
by Profile closed
Not applicable
Settings - Call - Wi-Fi Priority On.
That's what it is with the LG5 I've got. Its likely to be that for the LG7, too. Then turn phone off and on again. Then select your Wi-Fi. Then try making the call.
Does How do I set up WiFi Calling? / LG work for you?
by Profile closed
Not applicable
@Northerner wrote:
Hi @Hutch3
@Northerner, I think it is available. It is available on my LG5. Isn't the LG7 better and more than my LG5?
Thanks for your replies
I don't have the option in call settings like on the Lg5.
And because the Lg G7 Thinq wasn't purchased through EE themselves (as they don't supply it) it doesn't have the firmware needed for Wi-Fi calling.
I was hoping somebody might know how to put it on my device as I need it to work.
by Legend
Legend
@Hutch3
Where did you buy your handset from? Is it the UK/European version?
This service is also only available to pay monthly/ SIM only customers.
You would need to flash EE firmware if it's not available by default.
@Profile closed
There is no reason why it shouldn't be available on any handset tbh as it's an android setting that the manufacturer needs to activate.
Yes, the handset is a UK brand.
How do I get hold of the EE firmware to download onto my phone?
I have tried to look at my old lg5 to see if I can take it off there but I can't see how to do it.
Many thanks in advance
