by sarin
New Member
How can I keep voice message for more than seven days
How to keep voice messages more than 7 days
by Maestro
Maestro
Re: How can I keep voice message for more than seven days
Unless you have and iPhone and are using Visual Voicemail, there's is no way to save voicemails for any longer than the default 7 days sorry.
With iPhones and Visual Voicemail, the voicemail message is actually saved on the handset and you can also send send them as attachments.
Hi @sarin
Thanks for coming to community Smiley Happy
I hope the answer given kindly by @jmitchel helps to answer your question.
Have a great weekend.
Richard
Smiley Happy
by Skilled Contributor
Skilled Contributor
I guess there is a way of keeping messages longer than 7 days, and that's to not save them or delete once you've listened to them - but to leave them marked as "new" where I think the limit is 21 days, or certainly used to be.
The downside is that the "do I have new messages" flag and message count could get confusing if you forget that some of your "New" messages aren't actually new...
