EE WiFi Calling: All you need to know
What is EE WiFi Calling?
With EE WiFi Calling you can call and text even if you don't have a mobile signal.
All you need is a compatible phone and a WiFi connection.
Who can get EE WiFi Calling?
WiFi Calling is available to anyone using a compatible phone with an EE pay monthly plan.
The service is not currently available on pay as you go.
Is my phone compatible with EE WiFi Calling?
Alcatel
Read more
Device                                     Direct                                     Indirect*
A3
Read more
iPhone X, XS, XS Max, XR
iPhone 8, 8 Plus
iPhone 7, 7 Plus
iPhone 6, 6 Plus, 6s, 6s Plus
iPhone 5s, 5c
iPhone SE
Blackberry
Read more
Priv
DTEK 50
DTEK 60
KEYone
Doro
Read more
8035 No
EE
Read more
Device
Direct
Indirect*
Harrier
No
Harrier Mini
No
Hawk
No
HTC
Read more
A9 No
M9 No
Desire 530 No
10
U11
U11 Life
LG
Read more
Device
Direct
Indirect*
G4
No
G5
No
G6
No
K8 (2016 & 2017)
No
X Cam
No
K10
No
G5 SE
No
Microsoft
Read more
Device
Direct
Indirect*
Lumia 550
Lumia 650
Lumia 640 (& 640XL corporate only)
No
Lumia 950 (& 950XL corporate only)
Motorola
Read more
G7 Plus
G7 Power
G6 Play
Nexus
Read more
Device
Direct
Indirect*
5X
6P
OnePlus
Read more
6T
7 Pro
Google
Read more
Device
Direct
Indirect*
Pixel 3a
Pixel 3a XL
Pixel 3
Pixel 3 XL
Pixel 2
Pixel 2 XL
Pixel
Pixel XL
Read more
Device
Direct
Indirect*
Galaxy A3 (2016)
No
Galaxy A5 (2016)
No
Galaxy S5, S5 Neo
No
Galaxy S6, S6+, S6 Edge, S6 Edge+
Galaxy S7, S7 Edge
Galaxy A3 (2017)
Galaxy A5 (2017)
Galaxy S8
Galaxy S8+
Galaxy XCover 4
Galaxy J5 (2017)
Note 8
Galaxy S9
Galaxy S9+
J3 (2017)
J4+
Galaxy A6
Galaxy A7
Galaxy J6/J6+
Galaxy A8
Note 9
Galaxy S10, S10+ & S10e
Galaxy A9
Galaxy A40
Huawei
Read more
P10
P10 lite
P10 Plus
P9 No
P8 lite (2017)         No
P9 Lite No
P Smart
Mate 20 lite/Pro
P20 lite/Pro
P30
P30 Pro
Sony
Read more
Device
Direct
Indirect*
Xperia Z5, Z5 Compact, Z5 Premium
No
Xperia X
No
Xperia X Compact
No
Xperia XA
No
Xperia XZ
No
Xperia XZ Premium
No
Xperia L1
No
Xperia XZ1
Xperia XZ2
Xperia XZ3
Xperia L3
Xperia 10
Nokia (For Lumia devices, please see the Microsoft section above)
Read more
Device
Direct
Indirect*
3, 5 and 8
7.1
3.1
* Please check when buying a phone from a non-EE retailer whether or not it supports      WiFi Calling, as we cannot guarantee phones purchased from third parties will support    the feature.
If you need any help setting up WiFi Calling or experience any problems, please see the WiFi Calling Help page.
If you have any other questions, just tap reply and we'll get an answer for you.
13 REPLIES 13
by quentin_rayner Investigator
Re: EE WiFi Calling: All you need to know
I have a Huawei P30 PRO and prior to one of the last updates, wifi calling worked fine and kicked in when I had poor signal at home (2 bars or less). It now will not kick in at all if there is even a single bar. Is this how this feature works now as that makes it useless at home where a single bar is achievable, however calls are dropped so using it is not.
Hi @quentin_rayner.
Were you able to get the information you needed on your other thread?
Jon
Can you confirm the information in that thread is correct? The Android update has updated the logic in that it will stick with the mobile network even with a weak signal (e.g. 1 bar)?
If that is the case then wifi calling is pretty much useless in my house as I cannot get more than 1 bar and this is not strong enough to make or receive reliable phone calls. I get repeatedly dropped calls.
by Brilliant Contributor
@quentin_rayner
EE didnt make the change to make it prefer the mobile network signal.
It was done when devices were updated to Andeoid P.
It is google that made this decision.
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10/One UI 2.1)
Hi @quentin_rayner.
Did you try using airplane mode as suggested?
Have you tried WiFi Calling on someone else's WiFi too?
Jon
by Morchard02
I'm getting exactly the same issue. I've been on with EE tech support all afternoon with no luck. All they have done is re-enable WiFi calling. Yet it still no longer functions following android update.
it worked flawlessly before.
Good Morning @Morchard02.
Have you tried all the advice recommended by @Jon_K?
Speak soon,
Katie 🙂
by paulrichardson Valued Contributor
Valued Contributor
I am considering an EE contract, so I can use WiFi calling.
I have a Samsung Galaxy A3 2017 which was not purchased from EE
I have looked on my phone and there is no option to turn on WiFi Calling, will this option magically appear when I get my EE Sim?
Regards,
Paul
EE Community Team
Hi @paulrichardson,
Myself and @Schockwave  have responded to you on your other thread 🙂
The WiFi calling function will only be available if the phone was bought directly with EE. it doesn't matter if the SIM card you use is EE or a different provider.I
Alex 🙂
Valued Contributor
Hi Alex,
I’m sorry but the list on this page:-
https://community.ee.co.uk/t5/Calls/EE-WiFi-Calling-All-you-need-to-know/td-p/776855
Says the Galaxy A3 2017 doesn’t have to be purchased from EE
Regards,
Paul
Hi there @paulrichardson
Your right, is your handset running on the latest software?
If this option still does not show, I would recommend contacting Samsung support
Please keep us updated with your progress,
Katie 🙂
Valued Contributor
Hi Katie,
I just had a long chat with Samsung Technical Support.
They said
For the wifi calling feature, all you have to do is to reach your current network provider so that they can activate the wifi calling on your device since it's already available on the phone itself. They just need to activate it on their end as well.
So it looks like I need to get my EE contract set up and get EE to turn it on.
Regards,
Paul
@paulrichardson are you on Contract or PAYG?
