by Ace Contributor
Re: EE WiFi Calling: All you need to know
No it won't be rooted and if done correctly it won't void warranty.
I advise you follow the instructions. You need to flash all files
BrendonH (Android Expert) - Samsung Galaxy S10+ (Pie 9.0)
If I have helped you please click on the STAR/SOLUTION buttons below
by Twosey Investigator
Leanne,
I am told that the reason wifi calling wont work is because the phone has another carrires firmware on it - as I only use EE ( and have been a cust for many years) - would it be possible to get EE to flash the phone with their EE firmware - so that the wifi calling will show?
thx
Richard
by Ace Contributor
No EE can't force their firmware over to your phone.
You can do it but at your own risk.
Hello there @Twosey
I am sorry this is not possible.
We cannot guarantee phones purchased from third parties will support WiFi calling.
by treddien
How will EE Wifi calling work with the new dual SIM iPhone XS? Will wifi-calling be available in dual SIM mode?
Hi @treddien,
Welcome to the EE Community.
Yes, you'll be able to use EE WiFi Calling.
Thanks for your question. Smiley Happy
by Expert Contributor
Expert Contributor
In case it's of help to anyone. WiFi calling is working on my SIM-Free Honor View 20.
It needs to be turned on in Dual SIM settings. VoWifi 1 or VoWifi 2 will then appear in the status bar. (Depending which slot the EE Sim is used in) .
VoWifi only appears when the EE signal is weak.
Thanks for sharing @Techhead Smiley Happy
by sy2000
I have a follow up question and it might be a stupid question.
If someone has their phone on flight mode but have wifi calling enabled, will my call still go through or will it be rejected/go to voicemail as phone has wifi calling feature enabled?
thanks
by elverdiblanco Established Contributor
It should go through as normal. However on more than a few occasions my incoming calls have gone straight to voicemail even though Wi-Fi calling was enabled with airplane mode on.
