EE WiFi Calling: All you need to know
What is EE WiFi Calling?
With EE WiFi Calling you can call and text even if you don't have a mobile signal.
All you need is a compatible phone and a WiFi connection.
Who can get EE WiFi Calling?
WiFi Calling is available to anyone using a compatible phone with an EE pay monthly plan.
The service is not currently available on pay as you go.
Is my phone compatible with EE WiFi Calling?
Alcatel
Read more
Device                                     Direct                                     Indirect*
A3
Read more
iPhone X
iPhone 8, 8 Plus
iPhone 7, 7 Plus
iPhone 6, 6 Plus, 6s, 6s Plus
iPhone 5s, 5c
iPhone SE
Blackberry
Read more
Priv
DTEK 50
DTEK 60
KEYone
EE
Read more
Device
Direct
Indirect*
Harrier
No
Harrier Mini
No
Hawk
No
HTC
Read more
A9 No
M9 No
Desire 530 No
10
U11
U11 Life
LG
Read more
Device
Direct
Indirect*
G4
No
G5
No
G6
No
K8 (2016 & 2017)
No
X Cam
No
K10
No
G5 SE
No
Microsoft
Read more
Device
Direct
Indirect*
Lumia 550
Lumia 650
Lumia 640 (& 640XL corporate only)
No
Lumia 950 (& 950XL corporate only)
Nexus
Read more
Device
Direct
Indirect*
5X
6P
Google
Read more
Device
Direct
Indirect*
Pixel 2
Pixel 2 XL
Pixel
Pixel XL
Read more
Device
Direct
Indirect*
Galaxy A3 (2016)
No
Galaxy A5 (2016)
No
Galaxy S5, S5 Neo
No
Galaxy S6, S6+, S6 Edge, S6 Edge+
Galaxy S7, S7 Edge
Galaxy A3 (2017)
Galaxy A5 (2017)
Galaxy S8
Galaxy S8+
Galaxy XCover 4
Galaxy J5 (2017)
Note 8
Galaxy S9
Galaxy S9+
J3 (2017)
Galaxy A6
Galaxy J6
Galaxy A8
Note 9
Huawei
Read more
P10
P10 lite
P10 Plus
P9 No
P8 lite (2017)         No
P9 Lite No
P Smart
Sony
Read more
Device
Direct
Indirect*
Xperia Z5, Z5 Compact, Z5 Premium
No
Xperia X
No
Xperia X Compact
No
Xperia XA
No
Xperia XZ
No
Xperia XZ Premium
No
Xperia L1
No
Xperia XZ1
Xperia XZ2
Nokia (For Lumia devices, please see the Microsoft section above)
Read more
Device
Direct
Indirect*
3, 5 and 8
* Please check when buying a phone from a non-EE retailer whether or not it supports      WiFi Calling, as we cannot guarantee phones purchased from third parties will support    the feature.
If you need any help setting up WiFi Calling or experience any problems, please see the WiFi Calling Help page.
If you have any other questions, just tap reply and we'll get an answer for you.
by Skilled Contributor
Skilled Contributor
Re: EE WiFi Calling: All you need to know
I'm about to buy a brand new "unlocked" S9+ from ebay UK & I need to do my best to make sure that Wi-Fi calling will work as this is important to me.
Should a standard UK "Unlocked" S9+ coupled with my existing Pay Monthly EE sim work with Wi-Fi calling?
Hi @hotlips69
A Samsung S9+ purchased from another UK retailer should support WiFi calling, although we cannot guarantee it.
Find out more about compatible WiFi calling devices >
Skilled Contributor
So it's likely that if I buy a factory unlocked phone direct from Samsung, it should work with wi-fi calling?
Hello there @hotlips69
Thanks for coming back to us.
As @Christopher_G has advised, we cannot guarantee phones purchased from third parties will support WiFi calling.
Please check when buying a phone from a non-EE retailer whether or not it supports WiFi Calling.
Thanks, Leanne.
Skilled Contributor
Assuming the Wi-Fi calling may rely on having the EE firmware on the phone for the option to be available, can I simply flash with the stock EE firmware if required?
by Ace Contributor
Yes.
BrendonH (Android Expert) - Samsung Galaxy S8+ (Pie 9.0 Beta)
If I have helped you please click on the STAR/SOLUTION buttons below
by plunet
OK, I have an Honor V10.
I note it's not on the list of "approved" devices from EE for Wifi Calling. I accept that.
It has two SIM cards.
EE and 3
The EE SIM fails to register for Wifi Calling.
The 3 SIM does register and works for Wifi Calling.
The setting for Wifi calling on the Honor V10 appears to be for the phone - it's not per SIM.
If I take my EE SIM out of the Honor V10 and put it in a OnePlus 3 it works for Wifi Calling.
The OnePlus 3 is not an EE approved Wifi Calling device, yet it works.
Wifi Calling does work on the Honor V10, as the 3 SIM card demonstrates.
I accept that the device I'm using isn't on the list, but in principle it *should* work.
Anyone got any clue why it's not working, and what the difference is?
EE Employee
Hi @plunet and welcome to the community.
I understand your frustration but unfortunately we do not support dual SIM devices.
So our features i.e WIFI calling, 4G calling will not work.
Many thanks,
Lee
by plunet
Thanks for the very quick response @Lee_H
The odd thing is that the OnePlus 3 is a dual SIM device.
It also has the same two SIM cards in it - EE and 3
It's not on your approved list.
And it works.
Just out of curiosity - you seem to state that dual SIM devices do not work - is there a reason for this, either technical or policy, that can help the community's understand why this is the case? (even if it actually appears to work in practice on some dual SIM handsets)
EE Employee
Hi @plunet
Software versions are the main stumbling block.
A lot of dual SIM software does not have functions and features built in.
Many thanks,
Lee
by elverdiblanco Established Contributor
The OnePlus 6 is also a dual SIM device and not on the list of supported phones but there's plenty of evidence on other forums that it works with wifi calling on EE. EE might not 'support' it but that doesn't mean it shouldn't work. I'm having similar frustrations with a newly purchased HTC U12+ with wifi calling not working even though the HTC 10 and U11 had wifi calling working out of the box no matter where the phone was purchased.
by Twosey Investigator
Hi Brendon - are you able to share how you flashed your phone with EE software - as I bought my S9 plus from another carrier and the wi fi calling option isnt showing
by Ace Contributor
I will not explain how as if you brick your phone I take no responsibility.
You can Google though there are plenty of guides.
I would recommend sammobile.com
Where did you purchase the S9?
Dial *#1234# and share all info
Ok will take a look at site you suggested - is there any other way i can get wifi calling set up on phone?
AP G965FXXU1BRF8
CP G965FXXU1BRF5
CSC  G965FCKH1BRF1
MODEL SM-G965F
bought phone second hand - and as it was unlocked i didnt think it would be an issue -do the details i supplied show where phone originated from?
Hi there @Twosey
Where did you purchase the device?
Are you with us on pay as you go or pay monthly?
Thanks, Leanne Smiley Happy
Hi Leanne, thanks for looking into this for me. I bought the phone second
hand - and as it was unlocked , I assumed it wifi calling would work - my
last phone s7 had it . I have phoned Samsung who looked into the phone and
said it is a carrier issue and that EE should be able to get it working. I
contacted EE, who said they have sent a software message to phone so it
should work - but it doesn't!
Thx
Richard
richardtwose@btinternet.com
by Ace Contributor
You phone has Austrian Three firmware.
You won't receive Wi-Fi calling on this device unless you flash it.
when i flash it - will it be routed? - and void the warantee?   and to add wifi calling would it be just the CSC i would update to say a EE version?
