EE Voicemail: All you need to know
Voicemail is set up as standard for EE customers but is it free? Does it work abroad? What is Visual voicemail? Read on to find answers.
Is my voicemail set up already?
Voicemail is set up as default for all EE customers.
If you’re having any problems activating voicemail or if people can’t leave you messages, try texting “VM ON” to 150.
This will activate your voicemail divert and give the person calling you an option to leave a voicemail.
How do I access my voicemails?
There are a few ways you can listen to your voicemails on your EE device:
Option
Actions
1
Press and hold 1 or select voicemail (on an iPhone this is within the phone icon app) or dial 222
2
If you are calling from another phone within the UK dial 07953 222222 or +447953 222222 if you are calling from abroad
3
If you are calling from another phone you will need a voicemail PIN. To set this up call your voicemail (as above) and select option 3 then option 3
4
For help on voicemail for a particular phone model, go to our phones and device Help page where you can find more detailed information
Please see our EE Voicemail Help page for help on setting up a voicemail PIN.
How long will my voicemails be available for?
  • Your voicemail can store a maximum of 50 messages, up to 8 minutes each.
  • New messages are stored for 21 days and after you've listened to them, they can be saved and stored for a maximum of 7 days.
If a voicemail message hasn't been listened to you'll receive a free text alert to let you know it's about to be deleted. Voicemail messages are deleted automatically after 21 days.
Will I be charged for using my EE Voicemail?
What are voicemail diverts and how do I turn them on or off?
A voicemail divert is a setting that gives the person calling you an option to leave a voicemail.
If the setting is switched on, callers will have this option. If they are switched off, they won't be able to leave you a message and the call will either keep ringing or not ring at all if you're unreachable.
How to manage your voicemail diverts:-
  • Text VM ON to 150 to switch voicemail diverts on from the UK.
  • Text VM OFF to 150 to switch voicemail diverts off from the UK.
Do I need to do anything if I'm going abroad?
Depending on where you're travelling to, you may be charged for someone leaving you a voicemail.
If you have an active roaming call allowance, this will be deducted from your minutes.
You may want to turn diverts off if you’re going abroad.
Destination
Will I be charged for someone leaving me a voicemail?
Within the EU/EEA
No
Outside of the EU/EEA
Yes - You will be charged the normal
incoming call rate for the country you're
in.
For information on a specific destination,
please see our handy roaming tool.
If you call the voicemail number to retrieve a message, you will be charged the outgoing call rate for the country that you're in.
We recommend setting a voicemail PIN up before you leave the UK. You may need one of these to access your messages, depending on the roaming network that you connect to.
You can find information on how to do this on the EE Voicemail Help page.
Visual Voicemail - iPhone only
Visual Voicemail is a way to scan and manage your voicemails easily and instantly on your iPhone screen.
To get Visual Voicemail set up on your iPhone you’ll need to check a few things first;
Once you have this you're ready to go.
To activate Visual Voicemail text “iPhone Visual” to 150; you’ll get a text back when this has been set up.
If you’d like some more information on this, please see our EE Visual Voicemail Help page.
The EE Voicemail Help page is a brilliant place to find out more information about voicemail, including added security.
If you have any questions please tap the reply button below and ask away.
17 REPLIES 17
by DanTheMann
Re: EE Voicemail: All you need to know
How do I deactivate voicemail. I do not require this service. Without voicemail, people won't be offered the chance to leave me a message, and this is my preference. Voicemail was free when I purchased my phone and I was with One To One, and I do not want to pay EE as I didn't ask to be with them. Thanks.
by DanTheMann
Think I found the solution....
Text VM OFF to 150
Hope it works!
That's right @DanTheMann, texting VM OFF to 150 will turn off your voicemail service.
by Codender
New Member
My ordinary Nokia 6300 mobile has been getting answerphone /voice mail problem free up until 4 weeks ago when It told me I have not opted to receive voice mail ??
Today I have contacted 150 and their technical line & they have told me to enter VM ON by text to 150 , I have done this a dozen times without any confirmation text or change in the problem .
I am on an old PayAsYouGo option .
I do not want a SmartPhone or Monthly Contract
Has anyone else had this experience ?
Good Morning @Codender
It is a chargeable service to access your voicemail on pay as you go. A call to retrieve your voicemail is 35p per minute.
Katie 🙂
by Mattyding Investigator
Hey I’ve been with EE for 6 months and it’s become apparent I don’t have voicemail- even if my phone is off/out of signal it still rings out on the person calling me end- but I get no notification. Texting VM ON to 150 doesn’t work. Calling 150 doesn’t work as the guy I spoke to had ‘technical issues’ and promises to call me back at 10am today. No call received, but perhaps my signal was low and it rang out, and of course I wouldn’t be notified. Can I have some direction as to how to fix please ✌️
Hi @Mattyding,
We'll need to take a quick look at your account to see what is causing your voicemail issue.
Please head over to our get in touch page where you can chat with Customer Care online. They'll be happy to help. 🙂
by bondy1973 Investigator
Am I able to change the voicemail message and set my own?
I have been given a work device (Sony Xperia) which was previously assigned to someone else, they have set their own message on it and I would like to change it to my own.
Hi @bondy1973.
Welcome to the EE Community 🙂
If you press and hold the number 1 key to dial your voicemail, you can change the greeting within the settings by pressing option 2.
Hope this helps.
Jon
Thanks for the speedy reply.
When I hold the number 1 key, I get an error saying "Calls to this number are barred"?
Hi @bondy1973.
Are you able to make outgoing calls to any number?
Could you try dialling 222 instead?
Jon
Hi ,
I can make outgoing calls.
When I ring 222  it only gives options about messages received not my recorded message?
Thanks @bondy1973.
Once that announcement is finished, you should be presented with more options, including setting up or changing your greeting. Does this happen?
Jon
@Jon_K  No that doesn’t happen, I have listened to it all the way through and all the options offered take you back to the received messages.
Thanks @bondy1973.
Could you try texting VM OFF to 150 to remove voicemail, then restart the phone and text VM ON to 150 to enable it again?
Jon
@Jon_K
Hi when I texted that it came back with the message –
“We can’t give you your orange safeguard status at the moment. We’re aware of the problem so try again a bit later.”
Also it hasn’t taken the voicemail off either?
Thanks @bondy1973.
Is the SIM card an Orange or EE one?
When you dialled 222, did it give you any options to press to go to another menu?
Jon
