by Cheryl234 Investigator
Divert calls from mobile to landline
Does anyone know if I can divert calls made to my mobile onto my landline?
I have a Huawei P10lite
Solution
Re: Divert calls from mobile to landline
Thank you for that.
There is a missed out stage though,
You have to put the number you want the call to go to in and then press DISABLE.
This takes you back to the call forwarding screen where you can then go back into your call forward selection and pick ENABLE.
Bit of a strange way to do it but it does enable the call forwarding system!
Hi @Cheryl234
Yes you can. To set up please see here.
Solution
Thank you for that.
Hi @Cheryl234
Thanks for coming back and letting us know 🙂
Glad to hear you have now set up your call divert.
Come back to the community anytime.
Leanne 🙂
Recent solutions
