by steveyk Investigator
Calls failing and cannot receive calls
I can use the internet and I can text with no problems but people cannot call me and I cannot call them even with full bar. It just rings and then after 10 seconds it says call failed. This is my last ditch attempt to get some advise before I quit EE which is annoying because I never used to have any problems at all. I don't think it's my phone but I cannot be sure.
I have an iPhone 6s. At first I thought it was internet calling that might be the problem but it turns out it isn't. Any suggestions?
6 REPLIES 6
by Ace Contributor
Re: Calls failing and cannot receive calls
Hi @steveyk
Welcome to the EE Community,
Have you checked the EE network checker ?
https://myaccount.ee.co.uk/networkchecker/checkservice
Where are you?
Yes everything is ok according to EE
I am in Bristol St. George
Good Morning @steveyk
Does your handset show full signal?
Are you able to test your SIM in another device?
Speak soon, Katie 🙂
Good idea, I’ll try it in my old phone and let you know later.
Perfect, thank you very much @steveyk
Katie 🙂
