by Grumpy6
Calls don’t connect
I am currently in France and my calls to English numbers (+44) don’t connect. My data is working fine and calling a french number works as well.  Please can someone offer me advise.
Solution
Re: Calls don’t connect
Hi @Grumpy6
Have you enabled roaming and international calls?
Log into your on line account and then Menu - Manage Device - make sure you have activated roaming and international calls.
Or
From the MyEE app Current Usage - Controls - activate use phone abroad and make international and premium calls
Solution
Hi @Grumpy6
Or
by Grumpy6
I have just had a look and the phone abroad thing was turned off, I’ve just changed it but it said it could take a while, thank you for your help. Hopefully that works 🙂
@Grumpy6
Excellent.
Make sure you restart your device 👍🏼
Recent solutions
