by ScarlettSRS
Call forwarding not working
Hi, my call forwarding does not work. When I go into my call settings on my Oneplus 7 pro 5G then 'call forwarding settings' I try to turn on call forwarding for 'when unanswered' then  get error: 'call settings error-unexpected response from network'. This is a new EE umber from July 2019.
Re: Call forwarding not working
@ScarlettSRS  Unanswered calls go to voicemail. Do you have any other option to select ? call forwarding will redirect a call straight the way to a different device not if the call is not answered on the first device.
by ScarlettSRS
When someone calls me it just keeps ringing. It never goes to voicemail . The way explained are the only settings for calls
Afternoon @ScarlettSRS
Welcome to the community 🙂
If you would like to set up a voicemail can you text VM ON to 150.
Are you wanting to divert calls to a different number not voicemail?
Leanne 🙂
Recent solutions
