by admiralb
New Member
Call barring in Italy
Hi.
Just switched to EE from O2.
It Italy with work, and can't use my phone to call back to the UK.
It says that Call Barring is active, please deactivate to make a call.
When I check my account it says that roaming is active and enabled, so what else do I need to do???
Solution
Re: Call barring in Italy
@admiralb  you need to log into your account and enable called abroad and premium rate numbers then restart the device, it can take up to 24 hours to activate but it’s not usually this long.
Solution
Recent solutions
