by Selfie74 Investigator
CALLS FAILING AND TEXTS NOT DELIVERING
Can someone help please, I dial out and it says "call failed" and some texts "not delivered" im on a monthly contract so it is not a credit issue.  Ive reinserted my sim and the same thing happens!
My daughter is also with EE and is having the same problems.  Is there a problem with EE?
Its reallly frustrating not being able to use your phone when you really need to!!
Re: CALLS FAILING AND TEXTS NOT DELIVERING
Hi @Selfie74,
Welcome to the EE Community.
Does the Network Status Checker show any problems in your area?
Yes I did a Network check against my postcode and there were no faults.
Thanks for checking @Selfie74
Are you only experiencing this issue in one location or everywhere?
Does your phone show a network connection?
No it is happening in different locations.  Yep I have a network connection.
Hi @Selfie74,
We'll need to get our Tech Gurus to look into this in more detail.
Please get in touch and they'll be happy to help.
