Highlighted
by Investigator
wifi working but ethernet isn't.
when I diagnose the ethernet from the control panel it says it cant configure a valid IP address and nothing I've tried has worked so far
14 REPLIES 14
Highlighted
Re: wifi working but ethernet isn't.
Hi @mhands1
Your router ethernet should just work if you haven't changed any settings. What are you trying to do?
Have you also checked your cable?
Highlighted
Hi and welcome to the community, @mhands1
Have you tried the troubleshooting on our broadband help page?
Highlighted
What device are you using on Ethernet? If Windows, what does the command ipconfig /all report?
Highlighted
by Investigator
I have the ethernet cable plugged into an adapter then another adapter upstairs that has an ethernet cable plugged into my pc, its always worked until now.
Highlighted
by Investigator
Highlighted
Hi @mhands1
If you are using power line adapters, then try resynchronize them as they maybe out of sync with your router.
Highlighted
Sorry, it's the IP addys I'm interested in. There's no need to hide them ; they are just local.
Highlighted
by Investigator
Highlighted
Ah, I'm justified! Your PC has the IP 169.254.100.124 over Ethernet. PC's get that value IP when when they are not told which address to use by the router. Usually a reboot of the PC, reboot of the router, replug the LAN cable or use another router LAN port will cure it.
At the extreme it could be a fault of your powerlines not making a proper connection.
Which router is it? What is the DHCP page of the router? What is the list of currently connected devices?
Highlighted
How are you getting on, @mhands1?
I see @XRaySpeX may have made a breakthrough here.
Highlighted
by Investigator
Since i have rebooted the pc and router quite a few times as well as getting a new ethernet cable and trying all the ports on the back of the router im not sure what else to try.
i have the ee brightbox 2 wireless router
this is the list of currently connected devices   https://gyazo.com/4b0c6936fa30a046ac6e3ee8472ddcbf
Highlighted
Hi @mhands1
Are you using power line adapters as I mentioned above?
Highlighted
by Investigator
yes I'm using tp link av600
Highlighted
Then the issue is with the Powerlines. The presence of the PC is not being communicated to the router so the DHCP can allocate a local 192.168.1.x IP to it.Can you check their set-up & connections again?
