by EmmaDave1995 Investigator
why is my broadband so slow atm?
my broadband is so slow ATM? why? is there any sort of maintenance going on ?
my area is sr7 or is EE just carrying out any on there side?
my broadband normally sat at around 60mb around 4 month ago then it dropped to 30mb-50
now im currently sitting at 6mb #awfull!
6 REPLIES 6
Re: why is my broadband so slow atm?
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
4. What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
This is a list of your EE Smart Hub settings and current statistics.
Product name:Smart Hub
Serial number:+EEH001+1820011513
Firmware version:v0.00.24.06190-EE
Firmware updated:Tue Jul 31 16:28:32 2018
Board version:01
DSL uptime:0 Days, 1 Hours, 24 Mins, 25 Secs
Data rate:10.00 Mbps / 15.00 Mbps
Maximum data rate:14.75 Mbps / 55.41 Mbps
Noise margin (up/down):10.3 / 20.5
Line attenuation (up/down):25.5 / 18.2
Signal attenuation (up/down):25.3 / 18.2
Data sent / received:388.4 MB / 6.5 GB
Broadband username:PRODUCTIONHQNUN359643801@fs
2.4 GHz wireless network name:EE-Hub-kU5J
2.4 GHz wireless channel:Smart (Channel 6)
5 GHz wireless network name:EE-Hub-kU5J
5 GHz wireless channel:Smart (Channel 48)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:Default
MAC address:BC:30:D9:44:40:0C
Software variant:-
Boot loader:0.0.3-EE (Mon Dec 4 17:32:53 2017)
BT Broadband address checker
66.945.617.211.140AvailableAvailable
Please would you post the whole of the BT Availability Checker table for your phone no?
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability Date  High Low High Low      Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date
ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date
Observed SpeedsVDSLOther Offerings
Availability Date
VDSL Range A (Clean)66.945.617.211.140AvailableAvailable
VDSL Range B (Impacted)64.541.716.81035AvailableAvailable
FTTP on Demand33030--Available--
WBC ADSL 2+Up to 3--2.5 to 6.5Available--
ADSL MaxUp to 3--2 to 5.5Available--
WBC Fixed Rate1----Available--
VDSL Multicast------Available--
ADSL Multicast------Available--
What are EE's estimated speeds which your find in your MyEE for BB under Your broadband speed?
You must be running below EE's Min. Guaranteed Speed.
