by mike220963 Investigator
why does my router keep crashing. has happened twice in last 10 minutes ?
I turn my router off every morning for a couple of minutes and then back on as was told by ee that this helped router update .Lately router has been crashing a couple of times a day which is annoying but now it has crashed twice in 10 minutes which is making me think of changing supplier.
Solution
Re: why does my router keep crashing. has happened twice in last 10 minutes ?
There is no point in turning it off every day. Updates will come anyway; they come once in a blue moon anyway.
Do not restart your router to do this test:
Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
6 REPLIES 6
@mike220963   I only turn mine off once a month if that.  You don’t get updates every day.   Turn it off/unplug it for 5 minutes then switch it back on then see what happens.
Afternoon @mike220963
If you get in touch with our Broadband Gurus, they will be able to get this looked into for you.
Let us know how you get on 🙂
Solution
turns out it was a joint problem with my router being faulty and a fault on the line which was repaired by ee so many thanks for the help everyone 😊
Glad you're sorted, @mike220963.
Thanks for letting us know. 🙂
Thanks! You're welcome 🙂 ! Glad I could be of assistance & it is now sorted.
