by Helenlpearce
why can't i hear people on Skype
Whenever I use skype now I can't hear people on the other end of the video call, why is this?
6 REPLIES 6
by Star Contributor
Star Contributor
Re: why can't i hear people on Skype
Welcome to the Community. Can you hear them when using other chat apps?
Hi @Helenlpearce.
Welcome to the community. 🙂
Further to @Peter_C's question, can you hear people OK on normal calls?
If you record a video on the device camera or another app, are you able to hear the sound?
Look forward to hearing from you (no pun intended).
by Helenlpearce
We can hear normal calls fine, and we have tried from a pc to a mac in this country and it works fine. The problems we have been having are when we are trying to speak with realtives in Canada. The problem went away two weeks ago but has come back again last night.Thanks Helen
Hi @Helenlpearce,
What type of device are you using Skype on?
by Star Contributor
Star Contributor
As the problem is only with the canadians then the problem will be at their end. Skype is very flaky software.   I would guess they have inadvertently set their Skype setting to another input instead of the Microphone.  This may have been from using other software on their PC.
Advice- ask them to restart their PC, then restart skype.  Then to test skype call by using the skype testing service - it should be in their contacts. If that does not work, ask them to go to skype preferences and check audio/video. Select Audio input to internal microphone. Test again.
by Star Contributor
Star Contributor
One further point; if they are using an android tablet like an Amazon Fire Hd8 then they too are a bit temperamental with Skype. Amazon say it is supprted but the app is also very flaky. ( i think the theme here is that Microsoft are not very good at designing software). So in my experience tebooting the Tablet cures the sound issue.
