Highlighted
where is the wps button on my bright box 2 router
where is the wps button on my brightbox 2 router
Highlighted
by Ace Contributor
Solution
Re: where is the wps button on my bright box 2 router
Good Evening @0071
Welcome to the EE Community.
the WPS button is in the middle at the top on the back of the router if you press it for a few seconds it will activate wps.
15 REPLIES 15
Highlighted
by Ace Contributor
Solution
Good Evening @0071
Highlighted
many thanks.
Highlighted
New Member
When I press it, it flashes for about 2 seconds, then stops flashing.
having to press it really hard just to make the icon turn on.
Highlighted
Good Morning @Scottie16
Welcome to the EE Community, it's great to have you here.
Is this causing problems for you using your bright box router?
Speak soon,
Katie 🙂
Highlighted
How can I tell whether or not it is working?
i can’t see any lights and it does not appear to be connecting. I don’t know if this is the router or the extender I am trying to link
Highlighted
Hi @Stroller,
Which router are you using?
Highlighted
It looks like the Brightbox
Kind Regards
Sent from my iPhone
xxxx xxxxx
[mod edit: please do not post personal information on the public board. Thanks!]
Highlighted
Hi @Stroller,
Please take a look at Connect using WiFi Protected Setup (WPS) and let me know if it helps you get connected.
Highlighted
Hi, when I try to do WPS via PBC it doesn't work with the button and from the 192.168.1.1 menu I get a fault. Sometimes it takes about 2 to 3 minutes while it says "connecting"and then I get the error message.  Unfortunately the device I'm trying to connect, an Epson 245 printer, has no other way than WPS to connect, so manual set up won't work. Below is a screenhost.screenshot from router's WPS/PBC faultscreenshot from router's WPS/PBC fault
Highlighted
Do you really need to use PBC with it?
Highlighted
Trying to connect my Epson printer 2600 to the router. I have enabled WPS (which is the only way this printer connects) but even now it won't connect.
Please Help.
Highlighted
Hi @Philmo.
Are you using an additional device to make this connection between the router and the printer?
Is the printer able to be located by the device you're using?
Jon
Highlighted
Hi Jon,
Thanks for replying.
No, the printer Epson 2600 only connects to Wifi with the WPS button. I've enabled it on the router via the software and then the printer should detect it when I press the WiFi button. they both flash for a while - the router for 3 - 5 seconds and the printer for about 5 minutes...then nothing.
The printer is now sitting next to the router.
Highlighted
Is there an option to use a wired connection, @Philmo?
If the printer is next to the router, you could connect an ethernet cable, if there's a port on the printer.
Highlighted
We had to hold down the WPS button for around 20 seconds before the light started to flash. Hope its of help to others!
