by rnussbaum Investigator
very slow wifi
I have had EE broadband for over a year and always had a reasonable connection. In the last month the speed has massively reduced and now barely connects at all. I have tried some basic changes, moving the router, using the test socket, rebooting, but not had any success. Any help much appreciated, I'm not sure what to try next.
Speed test results here:
https://www.thinkbroadband.com/speedtest/1499072937400022655
0.2 mbps download
0.6 mbps upload
DSL status:
Line Status (Configured) - (Current) UP
Link type (Configured) - (Current) Interleaved Path
Operation Mode (Configured) Automatic (Current) G.992.5 / ADSL2+
Data Rate Information
Upstream 888kbps
Downstream 283 kbps
Defect/Failure Indication
Noise margin (Upstream) 17.6(dB) (Downstream) 29.9 (dB)
Line Attenuation (Upstream) 10.8(dB) (Downstream) 22.5 (dB)
System log
System Uptime is: 00:34:25
09:58:49, 03 Jul. Device connected: 192.168.1.217, 64:76:ba:af:85:c8, Gabriellas-Air, lease time is 172800 seconds
09:58:05, 03 Jul. Device connected: 192.168.1.217, 64:76:ba:af:85:c8, Gabriellas-Air, lease time is 172800 seconds
09:52:40, 03 Jul. Device connected: 192.168.1.160, cc:29:f5:72:e4:97, GabrielsiPhone2, lease time is 172800 seconds
09:51:39, 03 Jul. admin login success from 192.168.1.89
09:37:16, 03 Jul. Device connected: 192.168.1.130, ec:35:86:44:86:2c, Gabriellas-iMac, lease time is 172800 seconds
09:37:14, 03 Jul. Device connected: 192.168.1.217, 64:76:ba:af:85:c8, Gabriellas-Air, lease time is 172800 seconds
09:37:03, 03 Jul. Time is synced to NTP server
09:36:48, 03 Jul. PPP connection up (ADSL)
09:36:47, 03 Jul. PPP: IPCP up
09:36:46, 03 Jul. PPP: CHAP authentication succeeded
09:36:46, 03 Jul. PPP: LCP up
09:36:45, 03 Jul. PPP: Starting PPP daemon
09:36:43, 03 Jul. WAN link up (ADSL)
09:36:28, 03 Jul. Device connected: 192.168.1.89, a0:ce:c8:12:90:a1, Rosas-Air, lease time is 172800 seconds
09:36:23, 03 Jul. System up, firmware version: v0.00.14.0001-OT (Wed Jun 24 19:52:22 2015)
09:35:24, 03 Jul. System start
Solution
Very Slow Broadband
You should be syncing at about 19 Meg instead of the 283 K that you are. The reason you are not is that the DLM system has put you on a banded profile in response to past errors on your line, the lowest of these Banded Profiles, altho' you now have no significant errors. You need to call EE to reset the DLM in order to remove any banding. However should significant errors persist the DLM will reapply banding.
Re: very slow wifi
Hi @rnussbaum,
Welcome to the EE Community. Smiley Happy
Do you get the same results when using a wired connection rather than WiFi?
Re: very slow wifi
Hi James,
The line speed test results from the original post are from a wired connection. Using wifi only I get a max of 0.1mbps for upload and download speeds, and that's after running the test four times – the first three my connection timed out completely and the test failed.
Full results here
https://www.thinkbroadband.com/speedtest/1499083067863188755
Re: very slow wifi
Please post the full DSL Status page. It is incomplete.
The speedtests are irrelevant to this issue.
Re: very slow wifi
Status
Link Type   (Configured) -  (Current) Interleaved Path
Operation Mode     (Configured) Automatic    (Current) G.992.5 (ADSL2+)
Upstream   888kbps
Downstream  283kbps
Defect / Failure Indication
Noise Margin          (Upstream) 17.5 dB     (Downstream) 29.9 dB
Line Attenuation    (Upstream) 10.8 dB    (Downstream) 22.5 dB
Output Power    (Near End Indicator) 12.4 dBm   (Far End Indicator) 0.0 dBm
Fast Path FEC Correction    (Near End Indicator) --     (Far End Indicator) --
Interleaved Path FEC Correction    (Near End Indicator) 0    (Far End Indicator) 0
Fast Path CRC Error    (Near End Indicator) --     (Far End Indicator) --
Interleaved Path CRC Error    (Near End Indicator) 0    (Far End Indicator) 0
Loss of Signal Defect    (Near End Indicator) 0    (Far End Indicator) 0
Fast Path HEC Error STR    (Near End Indicator) --    (Far End Indicator) --
Interleaved Path HEC Error    (Near End Indicator) 0     (Far End Indicator) 0
Error Seconds    (Near End Indicator) 0     (Far End Indicator) 0
Statistics
Received Data       662767 kbits
Transmitted Data     137691 kbits
Solution
Very Slow Broadband
