by Chusux
very slow internet speed
My broadband speed has dropped about 2 weeks ago.
Wired speed test
Exchange
STATUS   Configured Current Line Status -- UP Link Type -- Interleaved Path Operation Mode Automatic G.992.5 (ADSL2+)
DATA RATE INFORMATION Upstream 1192 (Kbps) Downstream 575 (Kbps)
DEFECT/FAILURE INDICATION Operation Data Upstream Downstream Noise Margin 6.8 (dB) 36.6 (dB) Line Attenuation 18.8 (dB) 36.5 (dB)
Indicator Name Near End Indicator Far End Indicator Output Power 12.6 (dBm) 0.0 (dBm) Fast Path FEC Correction -- -- Interleaved Path FEC Correction 0 0 Fast Path CRC Error -- -- Interleaved Path CRC Error 0 0 Loss Of Signal Defect 0 0 Fast Path HEC Error STR -- -- Interleaved Path HEC Error 0 0 Error Seconds 0 0
STATISTICS Received Data 133120 (Kbits) Transmitted Data 36096 (Kbits)
What can I do?
Solution
Re: very slow internet speed
You should be syncing at about 11 Meg instead of the 575 K that you are. The reason you are not is that the DLM system has put you on a banded profile in response to past errors on your line, the 2nd lowest of these Banded Profiles, altho' you now have no significant errors. You need to call EE to reset the DLM in order to remove any banding. However should significant errors persist the DLM will reapply banding.
Solution
