by shiroma123
very slow internet speed
My broadband speed has suddenly dropped about 4 days ago, it was perfectly fine before.
Wired speed test: http://www.thinkbroadband.com/speedtest/results.html?id=1488319254419105955
Exchange: https://www.samknows.com/broadband/exchange/WEWMAI
Full router stats:
STATUS   Configured Current Line Status -- UP Link Type -- Interleaved Path Operation Mode Automatic G.992.5 (ADSL2+)
DATA RATE INFORMATION Upstream 1026 (Kbps) Downstream 283 (Kbps)
DEFECT/FAILURE INDICATION Operation Data Upstream Downstream Noise Margin 8.8 (dB) 13.5 (dB) Line Attenuation 23.9 (dB) 43.5 (dB)
Indicator Name Near End Indicator Far End Indicator Output Power 12.7 (dBm) 0.0 (dBm) Fast Path FEC Correction -- -- Interleaved Path FEC Correction 0 0 Fast Path CRC Error -- -- Interleaved Path CRC Error 0 0 Loss Of Signal Defect 0 0 Fast Path HEC Error STR -- -- Interleaved Path HEC Error 0 0 Error Seconds 0 0
STATISTICS Received Data 9522 (Kbits) Transmitted Data 1340 (Kbits)
Any help at all would be appreciated 🙂
Solution
Re: very slow internet speed
Thanks for supplying all the necessary data.
You should be syncing at about 7 Meg instead of the 283 K that you are. The reason you are not is that the DLM system has put you on a banded profile in response to past errors on your line, the lowest of these Banded Profiles, altho' you now have no significant errors. You need to call EE to reset the DLM in order to remove any banding. However should significant errors persist the DLM will reapply banding.
Solution
