by phil141990 Investigator
upgraded to fiber but speeds gone down no real answer from ee
Upgraded to fiber as it became available at our nearest "box" ie. so I understand there is fiber from exchange to the box and still the same copper from there to my house, but the speed has gone DOWN. (left for a number of weeks to settle down) Nothing has changed from box to my house and connection is straight to masterbox and router direct into it etc etc. any ideas please?  EE seem to be saying my line doesnt match fiber!!!!
6 REPLIES 6
Re: upgraded to fiber but speeds gone down no real answer from ee
Good Evening @phil141990
Welcome to the community.
Did our customer care team explain how your line does not match fibre?
Are you on a active fibre plan?
Speak soon, Katie 🙂
Did you actually upgrade your product with EE to Fibre or did you assume you will be auto upgraded cuz your cab can now do Fibre? Well, it won't unless you buy the Fibre package.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
4. What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
Yes upgraded in December, intial fault at exchange, fixed, left to settle, but my speed has actuallay gone down, be it only a little.  My understanding is that previously there was copper from the exchange (Inkberrow, Worcestershire) to box 602 and again copper to me.  Had consistent speed in upper 5's (5.7-5.9)    After upgrade this has dropped to upper 4's and occasional 5.
My understanding is that there is now fiber from exchange to box and still copper to me.  Two of my neighbours  have obtained significant increases on their pre upgrade.  My conversation with EE last week, they were unable to give a reason.     Being quite a simple person I asked with seemingly a higher speed to the box (half the distance from exchange to me) why the speed had not improved, be it a little!  I was given no real answer and the conversation went round and round until it was suggested that fibre might not be compatible.  I said that I had signed up for 6.1 to 12.3 and this had not been achieved.  I was then told that I had been advised on the order that EE had only guaranteed 4.4.  Hands up had not seen that, but when booked all the hype was that I would get an improvement.  Seems to me a big get out!   It was then suggest I could go back to original (copper) connection - where do I go from here?  Have done your tests, router is directly into masterbox, new cable etc etc.  Not very happy after 19 years with EE
Please provide the info I requested in my previous post.
No, Can't make it out. All linkys have been run together. Trying my best to unscramble:
@phil141990 wrote:
  1. http://192.168.1.254/status_log/+EEH001+1840004627_4067615_status.csv
  2. https://www.dslchecker.bt.com/adsl/adslchecker.TelephoneNumberOutput
  3. https://www.thinkbroadband.com/speedtest/1549664048457465255
  1. Presumably your router stats is a link into your LAN, which obviously can't be seen here.
  2. Intended to be the BTw Checker doesn't compute.
  3. Only this 1 correctly gives your speedtest results.
Please do again following my instructions to the letter.
