by Windins Investigator
tryingto connect 2 bbr1
Hi All,
im trying to link 2 bbr1's one being the master one being set to bridge mode.
i am on adsl which is working fine on the master router, additional settings of router 1
router ip address 192.168.1.1
dhcp start range has been changed to 192.168.0.3
dhcp range ends at 192.168.1.100
router 2
router is in fibre/ethernet mode and in bridging mode
router address is 192.168.1.2
dhcp start 192.168.1.101
dhcp end 192.168.254
i am trying to extend my lan network by using my old router as a network switch of which i have had success. but as soon as i unplug one of the 3 items the items lose internet signal altogether.
Any help gratiously recieved
Any more info required please ask
by Star Contributor
Star Contributor
Solution
Re: tryingto connect 2 bbr1
I would have the master setup as:
dhcp start range has been changed to 192.168.1.3
and then the other one with DHCP disabled and just running an IP out of the DHCP range of the master:
by Star Contributor
Star Contributor
Solution
on the night shift at the moment, but will try this when i get home and report back. Thanks for your help.
WOW your too good  just got home and tried it and as if by magic it all works.
cannot thankyou enough been playing with this for days now and sorted with one quick message to the community Excellent so glad i joined.
Morning @Windins
Come back to the community anytime 🙂
Have a great weekend.
Hey there want my number.....
its 192.168.1.1 maybe 192.168.1.2 lol
