by awolnonstop Investigator
slow fibre in speed test then goes quicker
Hi i was recently a customer with BT an just switched to EE. I find that running a speed test it gets stuck around 10mb then moves up to 50 at a slower pace. with bt it used to go up right away. does these settings look ok?
Status   Configured Current Line Status -- UP Link Type -- Fast Path Operation Mode Automatic G.993.2 (VDSL2)
Data Rate Information Upstream 19999 (Kbps) Downstream 79987 (Kbps)
Defect/Failure Indication Operation Data Upstream Downstream Noise Margin 15.2 (dB) 6.1 (dB) Line Attenuation 0.0 (dB) 8.4 (dB)
Indicator Name Near End Indicator Far End Indicator Output Power -8.2 (dBm) 12.6 (dBm) Fast Path FEC Correction 0 385 Interleaved Path FEC Correction -- -- Fast Path CRC Error 0 0 Interleaved Path CRC Error -- -- Loss of Signal Defect 0 0 Fast Path HEC Error STR 0 462 Interleaved Path HEC Error -- -- Error Seconds 162 81
Statistics Received Data 8309565 (Kbits) Transmitted Data 6174013 (Kbits)
Re: slow fibre in speed test then goes quicker
If you would like help with your BB speed or connection issues, please would you carry out the following steps for starters, which will enable us to diagnose the problem and advise you further.
1.  Your BB connection is fine.
2. There are speedtests & speedtests! Try a wired speedtest here http://www.thinkbroadband.com/speedtest.html and copy to here just the "Link to this result:" link.
the speed result was much better on this test
That's pretty good & fairly flat. Nowt to worry about there.
You are lucky to get fibre at that exchange. It was 1 of EE's "Off-Net" exchanges where they throttle ADSL, but not Fibre, at peak times. Do you notice any reduction in throughput speed at those times?
so far its been the same at all times ive run tests, tho i only have it a few days
