by aabb
New Member
slow broadband
my new contract should be superfast but is now slower than my old contract
Re: slow broadband
Hi @aabb,
Welcome to the EE Community.
Are you use mobile or home broadband?
Re: slow broadband
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
4. What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
