by pila Investigator
router
I have fibre boradband which I access with a brightbox wifi router. I have had it for 18 months with full access from every room of my 55sq/m flat. In the last two weeks, I can only connect in the room where the router is. Elsewhere, on my phne and tablet it shows I'm connected but there is no internet access. I have tried t reboot the router but nothing has changed. I haven't changed the position of the router and I cannt do it as there is only one phone plug
20 REPLIES 20
Re: router
What model is this router? How is it connected to the Brightbox? Have you set it up as a wireless extender? How? Which Brighrbox have you, the 1 or the 2?
You need explain more your arrangement for us to understand what you are getting at.
Re: router
it's brightbox 2, plugged into the phone socket and it is set us as a
wireless extender. It has ben working fine for 18 months and the internet
access problem has only emerged in the last 2 weeks
Re: router
Sorry, I misread that you had a 2nd router Smiley Embarassed.
If you would like help with your BB speed or connection issues, please would you carry out the following steps for starters, which will enable us to diagnose the problem and advise you further:
1. Post your full router stats. For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'Time Connected:' from initial Status page. Full router stats are key to any speed & connection issues.
2. Try both a wired & wireless speedtest here http://www.thinkbroadband.com/speedtest.html and copy to here just the "Link to this result:" link.
Re: router
1.
DSL STATUSThis page shows information about your DSL connection. If you are
using Ethernet Broadband then this page is not applicable.
STATUS
ConfiguredCurrent
Line Status -- UP
Link Type -- Fast Path
Operation Mode Automatic G.993.2 (VDSL2)
DATA RATE INFORMATION
Upstream 9995 (Kbps)
Downstream 39994 (Kbps)
DEFECT/FAILURE INDICATION
Operation DataUpstreamDownstream
Noise Margin 19.1 (dB) 13.5 (dB)
Line Attenuation 0.0 (dB) 10.3 (dB)
Indicator NameNear End IndicatorFar End Indicator
Output Power -4.2 (dBm) -4.2 (dBm)
Fast Path FEC Correction 277133 4
Interleaved Path FEC Correction -- --
Fast Path CRC Error 0 765
Interleaved Path CRC Error -- --
Loss Of Signal Defect 0 0
Fast Path HEC Error STR 0 115
Interleaved Path HEC Error -- --
Error Seconds 11 0
STATISTICS
Received Data 34294079 (Kbits)
Transmitted Data 4172780 (Kbits)
Time Connected 32:24:18
2.
http://www.thinkbroadband.com/speedtest/results.html?id=1484510706758478155
3. https://www.samknows.com/broadband/exchange/CLBER
Re: router
do you have any update on my router issue?
Re: router
I'm still waiting for the wired & wireless speedtest results from you as it would seem to be a wireless issue.
Re: router
I have sent them yesterday. Here them again:
1.
STATUS
ConfiguredCurrent
Line Status -- UP
Error Seconds 11 0
STATISTICS
2. http://www.thinkbroadband.com/speedtest/results.html?id=
1484510706758478155
Re: router
I know but in point 2. I'm asking for TWO speedtest links & which is which. This is a WiFi issue & so we must investigate your WiFi performance.
Re: router
thia the result page from the speedtest. there is no option to test wired or wireless
http://www.thinkbroadband.com/speedtest/results.html?id=1484686322166140055
Re: router
The option is whether you connect your PC from which you are running the speedtest to the router wired or wireless.
Re: router
I'm only able to connect my devices wireless
Re: router
In which case all I can say is that your BB connection is fine but the wireless variable. Wireless can be unreliable.
Re: router
however it's very inconvenient not to be able to use my devices through my
small flat, especially when I was able to do so until 2 weeks ago.
Re: router
Anything change internally 2 weeks ago?
When these devices lose connection do they disappear from the currently connected list in the router?
Re: router
No nothing.
Re: router
I'm sorry to see you are having problems @pila
Hopefully you will be able to get to the bottom of everything.
Richard
Re: router
the devices show that they are connected but there is no web access --  when I try to access a page I get the error message no internet connection check your connection.
Re: router
Are you talking about what the router shows or what the devices themselves show?
Re: router
The devices
