by ccawley
New Member
router restarting automatically
Hi. We have a problem where the EE router automatically restarts, in clusters. For example, it happened a few weeks ago where the router restarted three or four times without warning.
I have checked service status and line speed test, but nothing appears to be wrong. Can anyone tell me why this happens? Is it a problem with the router, or an update? Checking the log, I see the message:
DSL Link Down: duration was 43 seconds
Others this morning report
DSL Link Down: duration was 1639 seconds
DSL Link Down: duration was 70 seconds
Would appreciate any help.
by Skilled Contributor
Skilled Contributor
Re: router restarting automatically
How is your phone line?
Any pops and crackles when you dial 17070 option 2?
Which router? Is it a complete restart of the router or just a re-sync of the line?
Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
