by camicazz475 Investigator
port wont forward [25565]
I am trying to port forward my devicd on port 25565 to host a gaming server on my pc that my friends can connect to. This is on an EE BrightBox, I have succesfully port forwarded 3389, tested using canyouseeme.org, however when I try and port forward 25565 the port wont open.
Solution
Re: port wont forward [25565]
I rebooted my router and tried the new puplic IP and it seems to be working fine now, just got to set up a static IP then it'll be done.
@camicazz475 : Can you connect to port 25565 from your PC using the private LAN IP of the gaming server?
Yes I can connect to the server from a different system on the same LAN, however only by using the internal Private IP, the public IP wouldn't work (that may be normal, I'm not sure), However I could do that before port forwarding.
Yes, I was just checking that the server was up and running on that port.
Solution
Well done!
