by jayem22 Investigator
orange broadband router help
my broadband was set up in 2007 with cd installation and Orange router.  The computer it was set up on has gone and I have a new computer.  Don't have wifi.
I'm not getting a connection, but didn't really expect to, can someone help please, do I need to get an EE router
Solution
Re: orange broadband router help
Thank you XraySpex for mentioning the Ethernet cable.  I straightened the cable (it's very long) and managed to get online last night.  Only lasted a minute, so I straightened it more and here I am on the internet on my new comp, so far so good.   Thank you very much for your help
10 REPLIES 10
Which router have you? Is it the Siemens SE572-Router with the Orange branding?
Why should it stop working? What's changed?
Check its settings in Home Broadband settings.
i'll have to check the router and come back to you tomorrow, i'm using someone else's computer.
The only thing that has changed is the computer I used for the CD installation back in 2007 is deceased and I have a new PC.  I'll let you know tomorrow about the router.  Thank you
OK I'll wait on you.
Is it one of these?
HomeBroadbandDevice_Siemens.pngSiemensHomeBroadbandDevice_Livebox1_1.pngspeedtouch_330.gifSpeedtouch
 The last is the only 1 I remember needing a CD to set up. I hope it's not that.
hi, the first picture is it.  No mention of Siemens on it, but it says Orange Gigaset SE572 WLANdsi..........Product name: Ornge D12356.
I've never had wifi, do you think I need that now that I'm using a different PC to the one used for the CD installation.
I tried again this morning, clicked on Orange D12356 option, and it started verifying but then said "No internet, secured"
They also sent a "speedtouch" in the same box but I never used that.
Thank you
You don't need a CD for that 1. You can set it up manually using the settings in Home Broadband settings.
You could use WiFi but wired is more reliable. Have you connected it to the PC by Ethernet cable?
You might as well throw the Speedtouch away.
I'll have another go this evening and check everything's in properly - and throw the speedtouch thing away!!
Thank you for your help so far
EE Employee
Pop back and let us know how you get on @jayem22
Thanks - Karen. Smiley Happy
Solution
You're welcome :)! Glad I could be of assistance.
Sounds like you need a new Ethernet cable.
EE Employee
Happy to hear everything's now working @jayem22
Thanks for popping back to let us know!
Have a lovely evening.
