by endgame7 Investigator
new customer with broadband probs
only getting 16 mbs- but earlier today got 36
Solution
Re: new customer with broadband probs
@endgame7 : Welcome to EE's Home Broadband Forum.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
4. What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
12 REPLIES 12
Solution
i can't use an ethernet cable my MacBook doesn't support it
  1. Got it. Thanks. But it is too small to tead.
  2. Still do a wireless speedtest.
  3. Use: http://www.samknows.com/broadband/exchange_search and post the URL of your exchange page, not the original link I gave you.
  4. .Post an image of what you see, not the original link I gave you. Don't do it by postcode, but by your landline no.
Image 04-12-2019 at 21.06.jpgImage 04-12-2019 at 20.55.jpgImage 04-12-2019 at 21.07.jpg
Please do the router stats again but make it bigger.
Image 04-12-2019 at 21.17.jpgsorry i cant make it bigger
2. Please do the wireless speedtest at the site, ThinkBroadband, I sked for.
4. The BT checker is useless for Postcodes. Please do it for your landline no.
Im hitting 37 now X-ray
