Re: mastersocket wiring isnt connected but wifi works.
Somebody has disconnected them! Remember "The slave socket has no BB & phone signal as it not connected to the back of the faceplate of the master socket"?
by Ace Contributor
Could stick Ethernet jacks on them (assuming two pairs minimum each) and use them as slightly hacky Ethernet to then provide a wired LAN to the rooms!
by T5115 Investigator
Im confused as what you mean
I took of the whole thing and on the upstairs one there is two screws where a blue and white cable are attached to and that is it.
That's how it should be. To get a signal there the blue & the white/blue wires need connecting back at the master socket.
