by bristolash911 Investigator
leaving ee
i has been with EE since 3 months now i have speed issue keep losting connent ring EE to report it they find nothing wrong, try speed test my self i can sure you it crap so moving to SKY
Re: leaving ee
Hi @bristolash911
Who did you have before and what was the quality like?
Could it be your router which is faulty?
Thanks,
Re: leaving ee
Before you do let's just check whether it can be fixed, that you are getting the correct speeds & that you would get exactly the same from Sky. If it is your line that is faulty, all you'll be doing is taking it to another ISP w/out fixing it.
1. Post your full router stats. For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page. Full router stats are key to any speed & connection issues.
